Found a nice clean 40-130
I know the pre-sets but what else is different about the chassis? Tube lineup is the same.
Found a nice clean 40-130 - by Groundhog74 - 01-15-2016, 08:23 PM
RE: Found a nice clean 40-130 - by KCMike - 01-15-2016, 09:07 PM
RE: Found a nice clean 40-130 - by Paul Philco322 - 01-15-2016, 10:18 PM
RE: Found a nice clean 40-130 - by sam - 01-16-2016, 12:23 AM
RE: Found a nice clean 40-130 - by Squire - 01-16-2016, 12:57 AM
RE: Found a nice clean 40-130 - by Art Hoch - 01-25-2016, 07:51 PM
RE: Found a nice clean 40-130 - by SteveG - 01-25-2016, 08:28 PM
RE: Found a nice clean 40-130 - by Art Hoch - 01-29-2016, 11:55 AM
RE: Found a nice clean 40-130 - by Fred Taylor - 01-25-2016, 08:31 PM
RE: Found a nice clean 40-130 - by Groundhog74 - 01-26-2016, 02:38 PM
RE: Found a nice clean 40-130 - by Art Hoch - 01-29-2016, 12:01 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
