Fisher turntable and TX-300
Yeah...maybe back then.....(I did not imply DC cap saves it though, it does not even matter,simply allows unipolar DC amp to drive low ohms load) ....
I built two Ge transistor amps, the first being transformer output pushpull on Soviet P210
http://www.155la3.ru/p209.htm
(the largest Ge transistor at the time....well, the biggest of all times were P207-P208 but they were discontinued by that time)
http://www.155la3.ru/p207.htm
Behold. 74мм flange. The contacts were so this when one broke it was possible to drill in it, tap a thread and put a screw in. A 25A capable device, in those times.
Another was your regular pushpull with DC blocking cap on P215
http://www.radiolibrary.ru/reference/tra.../p215.html
These are smaller, about 10w dissip.
Fisher turntable and TX-300 - by OldRestorer - 01-27-2016, 01:50 PM
RE: Fisher turntable and TX-300 - by mikethedruid - 01-27-2016, 04:18 PM
RE: Fisher turntable and TX-300 - by OldRestorer - 01-27-2016, 04:36 PM
RE: Fisher turntable and TX-300 - by Ron Ramirez - 01-27-2016, 10:45 PM
RE: Fisher turntable and TX-300 - by OldRestorer - 01-28-2016, 10:15 AM
RE: Fisher turntable and TX-300 - by OldRestorer - 01-28-2016, 11:01 AM
RE: Fisher turntable and TX-300 - by Ron Ramirez - 01-28-2016, 01:55 PM
RE: Fisher turntable and TX-300 - by OldRestorer - 01-28-2016, 03:01 PM
RE: Fisher turntable and TX-300 - by Ron Ramirez - 01-28-2016, 04:14 PM
RE: Fisher turntable and TX-300 - by OldRestorer - 01-28-2016, 05:42 PM
RE: Fisher turntable and TX-300 - by Ron Ramirez - 01-28-2016, 07:30 PM
RE: Fisher turntable and TX-300 - by morzh - 01-28-2016, 08:49 PM
RE: Fisher turntable and TX-300 - by OldRestorer - 01-29-2016, 07:34 AM
RE: Fisher turntable and TX-300 - by codefox1 - 01-29-2016, 10:28 AM
RE: Fisher turntable and TX-300 - by Ron Ramirez - 01-29-2016, 01:12 PM
RE: Fisher turntable and TX-300 - by Ron Ramirez - 01-29-2016, 01:15 PM
RE: Fisher turntable and TX-300 - by OldRestorer - 01-29-2016, 02:56 PM
RE: Fisher turntable and TX-300 - by morzh - 01-29-2016, 08:09 PM
RE: Fisher turntable and TX-300 - by morzh - 01-29-2016, 08:15 PM
RE: Fisher turntable and TX-300 - by OldRestorer - 01-29-2016, 09:19 PM
RE: Fisher turntable and TX-300 - by morzh - 01-29-2016, 10:15 PM
RE: Fisher turntable and TX-300 - by Ron Ramirez - 01-29-2016, 10:20 PM
RE: Fisher turntable and TX-300 - by morzh - 01-29-2016, 10:42 PM
