Philco 89 Gee whiz
There were so many different versions of the Code 123 version of the 89 that some of these parts were added then removed. This was in between versions so it does not surprise me that there are some unused parts on the chasiis
Philco 89 Gee whiz - by simplex1040 - 01-25-2016, 09:52 AM
RE: Philco 89 Gee whiz - by Ron Ramirez - 01-25-2016, 04:11 PM
RE: Philco 89 Gee whiz - by simplex1040 - 01-25-2016, 05:20 PM
RE: Philco 89 Gee whiz - by Arran - 01-27-2016, 03:00 AM
RE: Philco 89 Gee whiz - by simplex1040 - 01-29-2016, 09:10 PM
RE: Philco 89 Gee whiz - by GarySP - 01-30-2016, 05:25 PM
RE: Philco 89 Gee whiz - by simplex1040 - 01-30-2016, 10:26 PM
There are currently 5459 online users. [Complete List]
» 1 Member(s) | 5458 Guest(s)
