Philco 37-116 lights
Actually I think this is probably a case of a revision that Philco made. Looking around on the web I do see a few other 37-116 chassis wired like mine with red and white wires. Those picture are also correlated with models not using the speaker plug - but earlier pin mechanism.
But... now I understand what you're talking about with the plug. Check out these pictures (don't remember where I grabbed these from - apologies if they belong to someone here on the Phorum! You might recognize your workbench...):
Philco 37-116 lights - by murf - 01-31-2016, 05:09 PM
RE: Philco 37-116 lights - by Nathan Slingerland - 02-01-2016, 12:46 AM
RE: Philco 37-116 lights - by Nathan Slingerland - 02-01-2016, 07:47 PM
RE: Philco 37-116 lights - by murf - 02-01-2016, 09:04 PM
RE: Philco 37-116 lights - by Nathan Slingerland - 02-01-2016, 09:35 PM
RE: Philco 37-116 lights - by murf - 02-02-2016, 09:35 PM
RE: Philco 37-116 lights - by Ron Ramirez - 02-24-2016, 10:48 PM
RE: Philco 37-116 lights - by murf - 02-28-2016, 11:10 AM
RE: Philco 37-116 lights - by Ron Ramirez - 02-28-2016, 11:51 AM
RE: Philco 37-116 lights - by murf - 02-28-2016, 12:41 PM
RE: Philco 37-116 lights - by 462ron - 02-28-2016, 02:30 PM
RE: Philco 37-116 lights - by murf - 02-28-2016, 05:39 PM
RE: Philco 37-116 lights - by PhilcoJohn - 03-02-2016, 08:06 PM
philco 37-116 lights - by murf - 02-24-2016, 06:32 PM
