37-61 photofinish... ideas ?
yes, Mike, the 37-610 is a different set of decals, larger than the 37-60/61 cabinet. I am not sure if the 37-640 is still another set. Anyway, Hank, I will be interested in seeing your results. I think the color is actually probably pretty close to the original. I know from violin work that reddish varnishes yellow and turn browner looking with age.
37-61 photofinish... ideas ? - by mikethedruid - 09-25-2015, 04:28 PM
RE: 37-61 photofinish... ideas ? - by ccomer1955 - 09-25-2015, 04:45 PM
RE: 37-61 photofinish... ideas ? - by ccomer1955 - 09-26-2015, 11:43 AM
RE: 37-61 photofinish... ideas ? - by Ron Ramirez - 09-26-2015, 08:23 PM
RE: 37-61 photofinish... ideas ? - by leftwing25 - 09-27-2015, 05:45 PM
RE: 37-61 photofinish... ideas ? - by Hank G - 01-30-2016, 03:39 PM
RE: 37-61 photofinish... ideas ? - by KCMike - 01-30-2016, 10:22 PM
RE: 37-61 photofinish... ideas ? - by KCMike - 01-31-2016, 07:26 PM
RE: 37-61 photofinish... ideas ? - by Hank G - 02-03-2016, 04:12 PM
RE: 37-61 photofinish... ideas ? - by KCMike - 02-03-2016, 05:50 PM
RE: 37-61 photofinish... ideas ? - by KCMike - 02-03-2016, 06:42 PM
RE: 37-61 photofinish... ideas ? - by mikethedruid - 02-03-2016, 08:58 PM
