37-116 chassis to 38-116 cabinet
Hi All,
   Are these two chassis interchangeable physically? I came across a beautiful 38-116 cabinet, missing the speaker and acoustic clarifiers and sound board. The chassis is there but rusted and was wondering if the chassis and speakers from my 37-116 would fit directly in this cabinet? Thanks
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
37-116 chassis to 38-116 cabinet - by 462ron - 02-05-2016, 03:27 PM
RE: 37-116 chassis to 38-116 cabinet - by 462ron - 02-05-2016, 05:54 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6797 online users. [Complete List]
» 1 Member(s) | 6796 Guest(s)
