37-116 chassis to 38-116 cabinet
Thanks Ron, yes the 37 is the Deluxe!
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
37-116 chassis to 38-116 cabinet - by 462ron - 02-05-2016, 03:27 PM
RE: 37-116 chassis to 38-116 cabinet - by 462ron - 02-05-2016, 05:54 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
