  • 1 Vote(s) - 4 Average
Philco 650PX Restore!
OK here is what I have to work with. The sides of cabinet are in bad shape and will have new wood substrate and mahogany veneer installed along with the lid cover that is hinged to swing open for the phonograph. The veneer on the top lid was all splitting and coming loose. The only way to make it new again is to replace it, this will take some time to do and will be costly for the veneer , may cost around $100 just for the veneer and substrate. The cabinet is gutted and I started on stripping the veneer on lid, then filled with a auto glaze then blocked sanded flat and smooth. This way the new veneer will have a nice flat surface to rest on. That's about all I got done today on it, had to work on some other radios as well.
Philco 650PX Restore! - by Fred Taylor - 02-06-2016, 10:38 AM
RE: Coming soon 650PX Restore! - by morzh - 02-06-2016, 11:55 AM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-06-2016, 07:20 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-07-2016, 12:26 AM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-07-2016, 12:34 AM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-07-2016, 08:57 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-07-2016, 09:14 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-07-2016, 09:18 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-07-2016, 09:24 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-07-2016, 09:33 PM
RE: Coming soon 650PX Restore! - by Crist Rigotti - 02-08-2016, 12:14 AM
RE: Coming soon 650PX Restore! - by OldRestorer - 02-08-2016, 01:18 AM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-08-2016, 07:54 AM
RE: Coming soon 650PX Restore! - by OldRestorer - 02-08-2016, 09:10 AM
RE: Coming soon 650PX Restore! - by Fred Taylor - 09-06-2016, 08:43 PM
RE: Coming soon 650PX Restore! - by Crist Rigotti - 02-13-2016, 08:10 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-13-2016, 09:33 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-14-2016, 04:38 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-20-2016, 08:51 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-20-2016, 08:55 PM
RE: Coming soon 650PX Restore! - by Crist Rigotti - 02-20-2016, 11:18 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 02-21-2016, 05:38 PM
RE: Coming soon 650PX Restore! - by Fred Taylor - 08-28-2016, 08:48 PM
RE: Coming soon 650PX Restore! - by KCMike - 08-28-2016, 09:05 PM
RE: Coming soon 650PX Restore! - by OldRestorer - 09-07-2016, 08:49 AM
RE: Coming soon 650PX Restore! - by Crist Rigotti - 09-07-2016, 09:01 PM
RE: Coming soon 650PX Restore! - by PhilcoJohn - 09-25-2016, 07:34 PM
RE: Coming soon 650PX Restore! - by klondike98 - 09-25-2016, 07:48 PM
RE: Coming soon 650PX Restore! - by Dennis Craft - 12-18-2016, 10:57 AM
RE: Coming soon 650PX Restore! - by Fred Taylor - 12-20-2016, 08:55 AM
Philco 91 Tuning Condenser
There are currently 10425 online users. [Complete List]
» 2 Member(s) | 10423 Guest(s)
