  • 1 Vote(s) - 5 Average
Wood grain on model 70
Jim Berg Wrote:I looked at my two 90's and my 70. The grain on the early 90's run with the arch, serial # 68898 May 9th 31, serial #83256 May 22nd 31. The grain on the 70 runs front to back. It has serial #640245 Sept 11th 31.
Woah! Now where do you locate the manufacture dates on the model 70?
tractorforum.com *** I reserve the right to be wrong
Wood grain on model 70 - by Music in a bottle - 04-26-2009, 07:05 PM
RE: Wood grain on model 70 - by Music in a bottle - 06-08-2012, 03:31 PM
RE: Wood grain on model 70 - by Music in a bottle - 06-09-2012, 11:09 PM
RE: Wood grain on model 70 - by Arran - 06-11-2012, 02:51 AM
RE: Wood grain on model 70 - by Steve Davis - 06-11-2012, 07:43 AM
RE: Wood grain on model 70 - by Eliot Ness - 06-11-2012, 10:45 AM
Re: Wood grain on model 70 - by Texasrocker - 04-27-2009, 02:24 AM
Re: Wood grain on model 70 - by Ron Ramirez - 04-27-2009, 06:49 AM
Re: Wood grain on model 70 - by Music in a bottle - 04-28-2009, 08:07 PM
Re: Wood grain on model 70 - by exray - 04-29-2009, 08:43 PM
Re: Wood grain on model 70 - by Music in a bottle - 04-29-2009, 09:30 PM
Re: Wood grain on model 70 - by Ron Ramirez - 04-29-2009, 10:26 PM
Re: Wood grain on model 70 - by exray - 04-30-2009, 08:26 AM
Re: Wood grain on model 70 - by Jim Berg - 04-30-2009, 08:00 PM
Re: Wood grain on model 70 - by Music in a bottle - 04-30-2009, 09:45 PM
Re: Wood grain on model 70 - by Music in a bottle - 04-30-2009, 09:46 PM
Re: Wood grain on model 70 - by Music in a bottle - 04-30-2009, 09:49 PM
Re: Wood grain on model 70 - by Jim Berg - 05-10-2009, 12:39 AM
Re: Wood grain on model 70 - by Music in a bottle - 05-10-2009, 10:41 PM
Philco 91 Tuning Condenser
