Philco Radiobar Glassware Inventory ??
Someone in the Phorum might be able to answer your question directly but I suspect your best chance at getting to that specific information is by visiting the Mulholland Press web site and contacting Robert Baumbach.  He has quite a bit of information on Radiobars.  Ron references this site as well in his discussion of Radiobars.  Robert has a contact page on the web site.  Let us know what you learn!
RE: Philco Radiobar Glassware Inventory ?? - by klondike98 - 02-10-2016, 04:22 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6970 online users. [Complete List]
» 1 Member(s) | 6969 Guest(s)
