ground antenna
If you look in the back of the radio, can you see a sticker with the Philco Model number? Either stuck to the metal chassis or a paper label of some sort against the left or right wall inside the cabinet?
Some Philco cathedral models were better performers than others. But like it has been mentioned here, a 20 ft. piece of wire should work fine on pretty much all off them and as well as rabbit ears.
The radio could have a problem, and if it has never been serviced, it really should be to avoid worse problems.
Mark K8KZ
ground antenna - by cowboy44 - 01-05-2016, 11:58 AM
RE: ground antenna - by Phlogiston - 01-05-2016, 02:53 PM
RE: ground antenna - by cowboy44 - 01-06-2016, 09:07 AM
RE: ground antenna - by klondike98 - 01-06-2016, 01:16 PM
RE: ground antenna - by Phlogiston - 01-06-2016, 02:32 PM
RE: ground antenna - by cowboy44 - 01-06-2016, 08:43 PM
RE: ground antenna - by cowboy44 - 01-19-2016, 08:51 PM
RE: ground antenna - by mikethedruid - 01-19-2016, 09:01 PM
RE: ground antenna - by Radioroslyn - 01-19-2016, 10:20 PM
RE: ground antenna - by cowboy44 - 01-20-2016, 05:42 PM
RE: ground antenna - by Paul Philco322 - 01-20-2016, 09:39 PM
RE: ground antenna - by Art Hoch - 02-04-2016, 12:22 PM
RE: ground antenna - by markmokris - 02-10-2016, 06:25 PM
RE: ground antenna - by AI2V - 02-16-2016, 01:22 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 10466 online users. [Complete List]
» 2 Member(s) | 10464 Guest(s)
