Philco 40-150 Code 121 Multiple Reception
I am working on a Philco 40-150 code 121 at the museum. The electrolytic and paper capacitors have been replaced. All tubes have been checked.
The problem is that I receive 1500 KHz at 530 on the dial, 580 on the dial, and 1500 on the dial.
What is going on? All suggestions are appreciated.
nv3g
Oscar -
Philco 40-150 Code 121 Multiple Reception - by NV3G - 05-01-2009, 04:58 PM
Re: Philco 40-150 Code 121 Multiple Reception - by don'tdomelikethat - 05-01-2009, 05:36 PM
There are currently 10563 online users. [Complete List]
» 3 Member(s) | 10560 Guest(s)
