Gojo question
Gojo is a cleaner.. Novus is only a polish as far as I know.
Gojo will remove all the crud and leave a nice clean finish once dried.
Novus would be the next step to finishing the cabinet... If the finish is good then you can apply the Novus polish accordingly. This will seal and protect the prepared finish. I dont use Novus really, I use plain old Johnsons paste wax on my radio cabinets and lots of elbow grease.
Kirk
Gojo question - by SteveG - 10-22-2015, 01:04 PM
RE: Gojo question - by SteveG - 10-22-2015, 10:44 PM
RE: Gojo question - by klondike98 - 10-22-2015, 11:18 PM
RE: Gojo question - by OldRestorer - 10-23-2015, 06:57 AM
RE: Gojo question - by OldRestorer - 10-23-2015, 06:59 AM
RE: Gojo question - by SteveG - 10-23-2015, 10:58 AM
RE: Gojo question - by sam - 10-23-2015, 11:51 AM
RE: Gojo question - by Eric Adams - 10-23-2015, 01:57 PM
RE: Gojo question - by Eliot Ness - 10-23-2015, 02:42 PM
RE: Gojo question - by OldRestorer - 10-23-2015, 04:24 PM
RE: Gojo question - by SteveG - 10-23-2015, 10:49 PM
RE: Gojo question - by TA Forbes - 10-24-2015, 08:43 PM
RE: Gojo question - by OldRestorer - 10-25-2015, 10:58 AM
RE: Gojo question - by TA Forbes - 10-29-2015, 07:40 AM
RE: Gojo question - by bastardbus - 02-01-2016, 03:02 PM
RE: Gojo question - by OldRestorer - 02-02-2016, 08:32 AM
RE: Gojo question - by Ian M. Gordon - 02-12-2016, 08:19 PM
RE: Gojo question - by OldRestorer - 02-12-2016, 09:56 PM
RE: Gojo question - by radiohenry - 02-13-2016, 09:37 AM
RE: Gojo question - by OldRestorer - 02-13-2016, 09:55 AM
RE: Gojo question - by Eliot Ness - 02-13-2016, 09:56 AM
RE: Gojo question - by OldRestorer - 02-13-2016, 11:51 AM
RE: Gojo question - by SteveG - 02-13-2016, 12:21 PM
RE: Gojo question - by Eliot Ness - 02-13-2016, 01:38 PM
RE: Gojo question - by radiohenry - 02-13-2016, 07:14 PM
There are currently 8561 online users. [Complete List]
» 1 Member(s) | 8560 Guest(s)
