Philco 37-650 Help
   Check this out--you tube---Philco 37-2670  part19,,,,about 4 minutes into the part,,,he will show you the way,,,Good luck,,
Philco 37-650 Help - by onlyrick - 02-11-2016, 10:46 PM
RE: Philco 37-650 Help - by Warren - 02-12-2016, 12:45 AM
RE: Philco 37-650 Help - by John Bartley - 02-12-2016, 08:02 AM
RE: Philco 37-650 Help - by klondike98 - 02-12-2016, 09:12 AM
RE: Philco 37-650 Help - by morzh - 02-12-2016, 09:58 AM
RE: Philco 37-650 Help - by onlyrick - 02-12-2016, 11:13 AM
RE: Philco 37-650 Help - by Kenneth F. Besso Jr. - 02-12-2016, 12:48 PM
RE: Philco 37-650 Help - by onlyrick - 02-12-2016, 06:06 PM
RE: Philco 37-650 Help - by onlyrick - 02-12-2016, 06:09 PM
RE: Philco 37-650 Help - by Kenneth F. Besso Jr. - 02-12-2016, 10:00 PM
RE: Philco 37-650 Help - by Kenneth F. Besso Jr. - 02-12-2016, 10:30 PM
RE: Philco 37-650 Help - by klondike98 - 02-12-2016, 10:53 PM
RE: Philco 37-650 Help - by davemc - 02-15-2016, 10:41 AM
RE: Philco 37-650 Help - by klondike98 - 02-15-2016, 12:45 PM
1 - 0v - correct 2 - 0v - correct 3 - 0v - --------------------- both 3 and 4 should be the same. Check L2 for being o...morzh — 05:13 PM
