610 info needed
Hi Wiz,
Long time no hear from!
Most of the time I don't worry too much about the schematic so much, just replace what is there.On the capacitor blocks you can reference the p# on the block to find the value and wiring. As long as the chassis hasn't been significantly altered it's not any problem. The 610 is a nice set to work on as it is pretty simple and straight forward. No sub chassis to disconnect (like a 37-610) although the 620 is a better performer having a stage of rf amplification and this helps with image rejection.
Have fun with your 610!
610 info needed - by ipwizard - 02-12-2016, 09:06 PM
RE: 610 info needed - by KCMike - 02-12-2016, 10:15 PM
RE: 610 info needed - by ipwizard - 02-13-2016, 07:11 PM
RE: 610 info needed - by klondike98 - 02-12-2016, 10:59 PM
RE: 610 info needed - by ipwizard - 02-13-2016, 07:05 PM
RE: 610 info needed - by Radioroslyn - 02-13-2016, 01:38 PM
RE: 610 info needed - by ipwizard - 02-13-2016, 07:09 PM
There are currently 5928 online users. [Complete List]
» 1 Member(s) | 5927 Guest(s)
