  • 1 Vote(s) - 1 Average
I must have a soft spot for Philcos...
Icon_lol
RE: I must have a soft spot for Philcos... - by OldRestorer - 02-16-2016, 01:01 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
