Tube Shield Finish
Does anyone know what the original finish was on the square tube shields used on 620's and 630's? Were they plated like the chassis?
Mine are in pretty rough shape, and I want to make them look original.
Derek
Tube Shield Finish - by Derek D - 01-04-2006, 11:24 AM
[No subject] - by Ron Ramirez - 01-05-2006, 12:49 PM
[No subject] - by Derek D - 01-05-2006, 12:59 PM
[No subject] - by 49Stude63 - 01-05-2006, 01:40 PM
[No subject] - by Terry Judkins - 01-05-2006, 10:06 PM
[No subject] - by Guest - 01-06-2006, 02:46 AM
