Model 20 recently acquired
    OK new to the site, but as I keep tripping over "old" Philcos, I thought I would join in with what I find here in the Great White North.
Just purchased a Model 20 which I see is referred to as the "Baby Grand". Looks to be a complete set although after research I has a couple of vacuum tubes that are incorrect for this set. I have seen a couple of online sites that feature restorations of this set and I have an idea of what I am in for. This is one of the oldest sets that I have run across locally. There had been a Radio station established in Fairbanks Alaska in 1923.
So, I'll try to post a couple of images here and will post questions and other images in the respective threads for electronic and cabinet repairs as I go along.
Model 20 recently acquired - by SteveinAlaska - 02-22-2016, 03:31 AM
RE: Model 20 recently acquired - by klondike98 - 02-22-2016, 09:21 AM
RE: Model 20 recently acquired - by GarySP - 02-22-2016, 09:36 AM
RE: Model 20 recently acquired - by Arran - 02-23-2016, 02:55 AM
RE: Model 20 recently acquired - by SteveinAlaska - 02-22-2016, 02:13 PM
RE: Model 20 recently acquired - by klondike98 - 02-22-2016, 02:29 PM
RE: Model 20 recently acquired - by morzh - 02-22-2016, 09:33 PM
RE: Model 20 recently acquired - by radiohenry - 02-22-2016, 09:50 PM
RE: Model 20 recently acquired - by Crist Rigotti - 02-22-2016, 09:51 PM
RE: Model 20 recently acquired - by morzh - 02-22-2016, 09:52 PM
RE: Model 20 recently acquired - by Arran - 02-23-2016, 03:04 AM
RE: Model 20 recently acquired - by GarySP - 02-23-2016, 10:01 AM
RE: Model 20 recently acquired - by gregb - 03-20-2016, 12:38 PM
RE: Model 20 recently acquired - by morzh - 03-20-2016, 12:51 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
