116B cap substitution?
I'd be a little surprised if it is a paper cap. Typically if the value is  in the uufd or mmfd and that it's in the rf section I'd bet it's a mica or perhaps a tubular ceramic.
Value wise don't know that you need to be dead on as it's coupling the osc output to the mixer. 50pf or so +/- probably isn't going to matter.
I would leave it. Not much voltage there, if it's shorted or or open it will cause the mixer to work won't burn out anything.
116B cap substitution? - by KCMike - 02-22-2016, 08:19 PM
RE: 116B cap substitution? - by gregb - 02-22-2016, 09:01 PM
RE: 116B cap substitution? - by Radioroslyn - 02-22-2016, 09:26 PM
RE: 116B cap substitution? - by KCMike - 02-22-2016, 09:40 PM
RE: 116B cap substitution? - by KCMike - 02-22-2016, 09:52 PM
RE: 116B cap substitution? - by Crist Rigotti - 02-22-2016, 09:57 PM
RE: 116B cap substitution? - by KCMike - 02-22-2016, 10:23 PM
RE: 116B cap substitution? - by doug-5er - 02-24-2016, 10:35 PM
There are currently 6086 online users. [Complete List]
» 2 Member(s) | 6084 Guest(s)
