Inside of a Philco 620 Cabinet
I'm wanting to clean up the inside of my 620 cabinet before I refinish the outside. Does anyone know what the original finish was for the inside of the cabinet? Is there a common practice for restoring?
Derek
Inside of a Philco 620 Cabinet - by Derek D - 01-04-2006, 11:29 AM
[No subject] - by Bill Hutchinson - 01-04-2006, 05:54 PM
[No subject] - by Derek D - 01-05-2006, 11:52 AM
[No subject] - by Ron Ramirez - 01-05-2006, 12:23 PM
[No subject] - by Ron Ramirez - 01-05-2006, 12:35 PM
[No subject] - by Derek D - 01-05-2006, 12:42 PM
[No subject] - by 49Stude63 - 01-05-2006, 01:59 PM
[No subject] - by Doug Houston - 01-24-2006, 07:57 PM
[No subject] - by Ken G - 03-21-2006, 11:37 PM
Philco 91 Tuning Condenser
