I need the technical manual model 46-806
They gave me a radio Philco 46-806 model, which does not have a speaker, or your transformer.
I have the outline, but I need to know how the speaker, dial and needle is mounted.
I need the technical manual model 46-806 - by Macan - 02-23-2016, 01:26 PM
There are currently 6262 online users. [Complete List]
» 2 Member(s) | 6260 Guest(s)
