70 speaker
Well
Nut is not the tell-tell; some of 90 speakers look same as 70 but electrically are like 20 for pushpull version and like 70 in SE.
The 4 wires mean pushpull (20 and some 90s), 3 mean SE, 70 and some other 90s.
70 speaker - by OldRestorer - 02-25-2016, 08:10 AM
RE: 70 speaker - by Fred Taylor - 02-25-2016, 08:57 AM
RE: 70 speaker - by OldRestorer - 02-25-2016, 11:26 AM
RE: 70 speaker - by Fred Taylor - 02-25-2016, 08:56 PM
RE: 70 speaker - by Steve Davis - 02-25-2016, 12:45 PM
RE: 70 speaker - by morzh - 02-25-2016, 09:26 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
