Philco 19 on/off switch?
I'm looking at this Philco 19 cathedral, and it looks to me like the AC line goes to the line filters and on to the power transformer. From there, it seems to go to an on/off switch mounted on the band switch? The volume pot doesn't have a switch on it at all. Looking at the schematic, the volume pot is where I expected to see the on/off switch.
On a side note, the volume pot is seriously stiff. I took it apart and cleaned it up, but it is still stiff. Again, no on/off switch.
NOTE: never mind. I should have known Ron had this information on the site. Thanks Ron. http://www.philcoradio.com/tech/19evol.htm
http://www.nostalgiaair.org/pagesbymodel...013151.pdf
Charlie in San Antonio
Philco 19 on/off switch? - by ccomer1955 - 02-27-2016, 01:13 PM
RE: Philco 19 on/off switch? - by ccomer1955 - 02-27-2016, 01:28 PM
RE: Philco 19 on/off switch? - by markmokris - 02-27-2016, 06:15 PM
RE: Philco 19 on/off switch? - by klondike98 - 02-27-2016, 04:50 PM
RE: Philco 19 on/off switch? - by KCMike - 02-27-2016, 06:27 PM
RE: Philco 19 on/off switch? - by ccomer1955 - 02-27-2016, 10:44 PM
There are currently 5795 online users. [Complete List]
» 3 Member(s) | 5792 Guest(s)
