philco pt2
Yeah !!! Hey guys its WORKING !!!!
I found a bad solder joint at the off/on volume control and the 7C6 tube had gone bad. Luckily I had another one to replace it. I hooked up the loop antenna from another radio to the pT2 since I don't have an antenna for it. It sounds kind of tinny with high treble but I can get several local stations on it . But I guess you can't expect too much from a 75 year old speaker that's been patched a few times. No telling when was the last time it actually worked. Anyway, its always a thrill to hear an old relic like this come back to life. Thanks for all your help . You are a great bunch of experts.
wally73
philco pt2 - by wally73 - 02-25-2016, 10:20 AM
RE: philco pt2 - by TV MAN - 02-25-2016, 12:29 PM
RE: philco pt2 - by TV MAN - 02-25-2016, 12:58 PM
RE: philco pt2 - by klondike98 - 02-25-2016, 01:19 PM
RE: philco pt2 - by wally73 - 02-26-2016, 05:20 PM
RE: philco pt2 - by wally73 - 02-26-2016, 06:15 PM
RE: philco pt2 - by Radioroslyn - 02-27-2016, 12:38 AM
RE: philco pt2 - by Arran - 02-27-2016, 02:55 AM
RE: philco pt2 - by TV MAN - 02-27-2016, 01:18 PM
RE: philco pt2 - by wally73 - 02-27-2016, 01:31 PM
RE: philco pt2 - by klondike98 - 02-27-2016, 04:46 PM
There are currently 6674 online users. [Complete List]
» 2 Member(s) | 6672 Guest(s)
