Proper Model 21 chassis mtg.
Heart
My model 20 did not have any bushings when I disassembled it.  I don't think the 21 was much different chassis-wise. Shim it with the hard rubber washers if that's what it takes to align it to the cabinet.  None of us are going to come down on you for it.  I for one believe in the "whatever makes it work and not look obvious" approach.  Take care, Gary
Proper Model 21 chassis mtg. - by Tubesforme - 02-22-2016, 07:57 PM
RE: Proper Model 21 chassis mtg. - by klondike98 - 02-27-2016, 08:41 AM
RE: Proper Model 21 chassis mtg. - by Tubesforme - 03-01-2016, 05:56 PM
RE: Proper Model 21 chassis mtg. - by GarySP - 02-27-2016, 03:50 PM
RE: Proper Model 21 chassis mtg. - by Tubesforme - 03-01-2016, 05:58 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1352 online users. [Complete List]
» 3 Member(s) | 1349 Guest(s)
