Philco 37-116 lights
Got my lights and rebuilt them yesterday.
Hooked up to a 6 volt battery and they all lit.
Tried hooking up to the 2 wires coming from chassis and got nothing.
Looks like these 2 wires are coming from a terminal block that is wired to the magnetic tuning switch.
Am I looking at a bad switch?
Does work to control magnetic tuning.
I am at a loss here.
Any ideas?
murf
Philco 37-116 lights - by murf - 01-31-2016, 05:09 PM
RE: Philco 37-116 lights - by Nathan Slingerland - 02-01-2016, 12:46 AM
RE: Philco 37-116 lights - by Nathan Slingerland - 02-01-2016, 07:47 PM
RE: Philco 37-116 lights - by murf - 02-01-2016, 09:04 PM
RE: Philco 37-116 lights - by Nathan Slingerland - 02-01-2016, 09:35 PM
RE: Philco 37-116 lights - by murf - 02-02-2016, 09:35 PM
RE: Philco 37-116 lights - by Ron Ramirez - 02-24-2016, 10:48 PM
RE: Philco 37-116 lights - by murf - 02-28-2016, 11:10 AM
RE: Philco 37-116 lights - by Ron Ramirez - 02-28-2016, 11:51 AM
RE: Philco 37-116 lights - by murf - 02-28-2016, 12:41 PM
RE: Philco 37-116 lights - by 462ron - 02-28-2016, 02:30 PM
RE: Philco 37-116 lights - by murf - 02-28-2016, 05:39 PM
RE: Philco 37-116 lights - by PhilcoJohn - 03-02-2016, 08:06 PM
philco 37-116 lights - by murf - 02-24-2016, 06:32 PM
1 - 0v - correct 2 - 0v - correct 3 - 0v - --------------------- both 3 and 4 should be the same. Check L2 for being o...morzh — 05:15 PM
