IF mica replacement value Philco 49-1405 model
Hello Exray,
thanks for the tip far as the caps go .
I'm glad I have good stock of both Disc and mica caps to .
Sincerely Rich
Re: IF mica replacement value Philco 49-1405 model - by radiorich - 05-10-2009, 02:05 AM
There are currently 4295 online users. [Complete List]
» 1 Member(s) | 4294 Guest(s)
