Proper Model 21 chassis mtg.
(02-27-2016, 08:41 AM)klondike98 Wrote:  I'm not sure what might have been originally there but rubber washers were used in a number of Philco radio mounts.  Renovated radios has a nice selection in the Chassis Mounts section.  If that's what is needed to line up the shafts, I wouldn't hesitate to use them.  One under each of the three mounts should keep it level.
Thanks, I had ordered the 1/8" chassis mount washers from Ed and while waiting for them to arrive decided if anyone knew something I didn't and I know there are many great restorers, out there! Thank you.
Proper Model 21 chassis mtg. - by Tubesforme - 02-22-2016, 07:57 PM
RE: Proper Model 21 chassis mtg. - by klondike98 - 02-27-2016, 08:41 AM
RE: Proper Model 21 chassis mtg. - by Tubesforme - 03-01-2016, 05:56 PM
RE: Proper Model 21 chassis mtg. - by GarySP - 02-27-2016, 03:50 PM
RE: Proper Model 21 chassis mtg. - by Tubesforme - 03-01-2016, 05:58 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1469 online users. [Complete List]
» 2 Member(s) | 1467 Guest(s)
