Proper Model 21 chassis mtg.
(02-27-2016, 03:50 PM)GarySP Wrote:  My model 20 did not have any bushings when I disassembled it.  I don't think the 21 was much different chassis-wise. Shim it with the hard rubber washers if that's what it takes to align it to the cabinet.  None of us are going to come down on you for it.  I for one believe in the "whatever makes it work and not look obvious" approach.  Take care, Gary
I agree, I know that I had never before seen a model 20 that used the washers, but my 21 did need a 1/8" lift to align the shafts properly. Thanks Gary.
Proper Model 21 chassis mtg. - by Tubesforme - 02-22-2016, 07:57 PM
RE: Proper Model 21 chassis mtg. - by klondike98 - 02-27-2016, 08:41 AM
RE: Proper Model 21 chassis mtg. - by Tubesforme - 03-01-2016, 05:56 PM
RE: Proper Model 21 chassis mtg. - by GarySP - 02-27-2016, 03:50 PM
RE: Proper Model 21 chassis mtg. - by Tubesforme - 03-01-2016, 05:58 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
There are currently 3185 online users. [Complete List]
» 2 Member(s) | 3183 Guest(s)
