replacing missing loop antenna Philco 49-1405
Hi Rich
The 5 pF cap is in series with the external antenna lead.
Otherwise I'm afraid I can't help you much with this issue...
Re: replacing missing loop antenna Philco 49-1405 - by Ron Ramirez - 05-12-2009, 05:34 PM
There are currently 9881 online users. [Complete List]
» 1 Member(s) | 9880 Guest(s)
