Model 90 Output Transformer
Standard color code for audio output transformer primary is Blue lead is the plate(top), Red lead is B+(ct), Brown is the other Plate lead for  P/P output (bottom). Secondary is Green or copper wire.
Model 90 Output Transformer - by rrova - 03-02-2016, 03:52 AM
RE: Model 90 Output Transformer - by klondike98 - 03-02-2016, 08:07 AM
RE: Model 90 Output Transformer - by morzh - 03-02-2016, 09:29 AM
RE: Model 90 Output Transformer - by Radioroslyn - 03-03-2016, 02:19 AM
RE: Model 90 Output Transformer - by rrova - 03-03-2016, 04:53 AM
RE: Model 90 Output Transformer - by Arran - 03-03-2016, 05:20 AM
RE: Model 90 Output Transformer - by rrova - 03-04-2016, 06:05 AM
RE: Model 90 Output Transformer - by morzh - 03-04-2016, 10:34 AM
RE: Model 90 Output Transformer - by rrova - 03-04-2016, 05:43 PM
RE: Model 90 Output Transformer - by morzh - 03-04-2016, 07:32 PM
RE: Model 90 Output Transformer - by rrova - 03-04-2016, 08:37 PM
RE: Model 90 Output Transformer - by morzh - 03-04-2016, 09:24 PM
RE: Model 90 Output Transformer - by rrova - 03-04-2016, 09:53 PM
RE: Model 90 Output Transformer - by morzh - 03-04-2016, 09:58 PM
RE: Model 90 Output Transformer - by rrova - 03-04-2016, 10:07 PM
RE: Model 90 Output Transformer - by Tubesforme - 03-08-2016, 03:41 PM
RE: Model 90 Output Transformer - by rrova - 03-05-2016, 04:01 AM
RE: Model 90 Output Transformer - by Radioroslyn - 03-05-2016, 08:06 PM
RE: Model 90 Output Transformer - by rrova - 03-05-2016, 08:53 PM
RE: Model 90 Output Transformer - by morzh - 03-05-2016, 08:53 PM
RE: Model 90 Output Transformer - by Radioroslyn - 03-05-2016, 10:35 PM
RE: Model 90 Output Transformer - by morzh - 03-05-2016, 11:15 PM
RE: Model 90 Output Transformer - by rrova - 03-07-2016, 02:47 AM
RE: Model 90 Output Transformer - by morzh - 03-08-2016, 03:51 PM
RE: Model 90 Output Transformer - by rrova - 03-08-2016, 06:17 PM
RE: Model 90 Output Transformer - by Tubesforme - 03-09-2016, 10:59 PM
RE: Model 90 Output Transformer - by rrova - 03-09-2016, 11:04 PM
RE: Model 90 Output Transformer - by Tubesforme - 03-12-2016, 05:47 PM
RE: Model 90 Output Transformer - by Tubesforme - 03-10-2016, 08:35 PM
RE: Model 90 Output Transformer - by morzh - 03-08-2016, 06:50 PM
RE: Model 90 Output Transformer - by rrova - 03-09-2016, 05:33 PM
RE: Model 90 Output Transformer - by morzh - 03-09-2016, 05:39 PM
RE: Model 90 Output Transformer - by morzh - 03-10-2016, 11:33 AM
RE: Model 90 Output Transformer - by morzh - 03-10-2016, 09:19 PM
RE: Model 90 Output Transformer - by rrova - 03-11-2016, 01:06 AM
RE: Model 90 Output Transformer - by morzh - 03-11-2016, 10:36 AM
RE: Model 90 Output Transformer - by Arran - 03-13-2016, 05:31 AM
Restoring Philco 96
There are currently 7491 online users. [Complete List]
» 2 Member(s) | 7489 Guest(s)
