Philco 41-290X Band Selector help
My Philco 41-290X has two cords: one for the tuning dial and the other for band selector. Luckily, the turner is still strung but the cord for the band selector light box was broken when I acquired the set. Does anyone have this set and can show how to string it? There is a rotating switch, the turning of which moves the cord whin in turn moves the light box to indicate the band. And, newbie that I am, I can't tell even which position the switch should be in to start the re-cording. Any clues, or where to look would really help!
Thanks!
=-jp-=
Philco 41-290X Band Selector help - by Guest - 05-12-2009, 08:04 PM
Re: Philco 41-290X Band Selector help - by Guest - 05-13-2009, 10:04 PM
There are currently 10690 online users. [Complete List]
» 3 Member(s) | 10687 Guest(s)
