How to glue in new speaker cloth?
Mike,
Thanks for the link.
Does anyone know the best way to tone down the newness on cloth that's going in an unrestored cabinet? There are some suggestions in that link, but I'm curious what method has worked best?
How to glue in new speaker cloth? - by SteveG - 03-04-2016, 12:07 AM
RE: How to glue in new speaker cloth? - by KCMike - 03-04-2016, 01:53 PM
RE: How to glue in new speaker cloth? - by SteveG - 03-05-2016, 05:07 PM
There are currently 9625 online users. [Complete List]
» 1 Member(s) | 9624 Guest(s)
