Wow! A busy day with the SX-1500TD.
First, I tackled the power supply board:
[Image: http://www.philcoradio.com/images/phorum..._00007.jpg]
Here's how it looked after removal from the receiver:
[Image: http://www.philcoradio.com/images/phorum..._00009.jpg]
and after all electrolytic capacitors, transistors, and diodes had been replaced:
[Image: http://www.philcoradio.com/images/phorum..._00011.jpg]
There is also a small board which controls the FM Stereo lamp that contains an electrolytic cap, a diode, and a transistor. This, too, was completely rebuilt.
RE: Ron's Pioneer SX-1500TD - by Ron Ramirez - 03-05-2016, 11:18 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
