Output transformer secondary Lugs for PP42 on Model 650?
Typically triodes have a lower plate impedance than pentodes. Even pentodes that are wired as a triode. When trying find the proper impedance most tube manuals don't list penodes in that configuration. Good thing Ron has the info for the original.
Restoring Philco 96
There are currently 7490 online users. [Complete List]
» 2 Member(s) | 7488 Guest(s)
