Output transformer secondary Lugs for PP42 on Model 650?
Thank you. Glad I'm checking with the experts. So on the RCA tube data sheet, the option with the screen grid connected to plate in push pull configuration would be the correct load impedance? 6000 ohms? fixed bias.
Thanks again,
Dave
Restoring Philco 96
There are currently 7569 online users. [Complete List]
» 2 Member(s) | 7567 Guest(s)
