Philco Model 59
Hi Chris,
red would be 8uf (connected to 80 or b+ line somewhere) green 4uf (goes to the field coil) and they would share the black negative which goes to the center tap.
Going on memory from about a year ago recap.......... I'll try and double check this tonight..
Philco Model 59 - by Chris Drumma - 01-04-2006, 10:14 AM
[No subject] - by Jerry Huelsbeck - 01-04-2006, 01:00 PM
[No subject] - by Chris Drumma - 01-05-2006, 10:19 AM
[No subject] - by Jerry Huelsbeck - 01-05-2006, 11:19 PM
[No subject] - by Chris Drumma - 01-06-2006, 08:44 AM
[No subject] - by Jerry Huelsbeck - 01-06-2006, 01:43 PM
There are currently 8989 online users. [Complete List]
» 2 Member(s) | 8987 Guest(s)
