Zenith C725 help!
When recapping if it was my radio I would replace the selenium diode. You will need to change the value of the 22 ohm resistor (R3?) to something around 50 ohms then check voltage and adjust. I have had good luck with 19T8 and 35C5 tubes in Z sets. Glad to see your set has a 12AT7  instead of 12DT8 that is the tube I have the most problems with in Z sets. Give the slide switch a good cleaning. Good Luck David
Zenith C725 help! - by TheUniversalDave1 - 03-07-2016, 12:32 AM
RE: Zenith C725 help! - by Radioroslyn - 03-07-2016, 07:12 AM
RE: Zenith C725 help! - by TV MAN - 03-07-2016, 12:13 PM
RE: Zenith C725 help! - by TheUniversalDave1 - 03-07-2016, 02:56 PM
RE: Zenith C725 help! - by David - 03-07-2016, 09:06 PM
RE: Zenith C725 help! - by TheUniversalDave1 - 03-07-2016, 11:09 PM
RE: Zenith C725 help! - by doc612 - 03-09-2016, 10:33 PM
RE: Zenith C725 help! - by TheUniversalDave1 - 03-10-2016, 10:34 AM
RE: Zenith C725 help! - by TV MAN - 03-11-2016, 10:37 AM
There are currently 10910 online users. [Complete List]
» 3 Member(s) | 10907 Guest(s)
