48-1256 alignment help.
Getting geared up to do the AM alignment on the 48-1256 I've been slowly trying to restore.  Never done one of these on my own before, so I've got a few questions.
For reference, here's a pic of the alignment instructions from Sam's:
[Image: http://i.imgur.com/Y42Czls.jpg]
1. I have an isolation transformer.  Am I reading that correctly that if I use it, I won't need to solder in the .01uf or 200pf caps?
2. What does it mean in the coupling section about high side & low side?  And where do I access B-?
3. Any idea what that smudged section under Output Meter might have said?
48-1256 alignment help. - by captainslack - 03-10-2016, 02:52 PM
RE: 48-1256 alignment help. - by Radioroslyn - 03-10-2016, 05:25 PM
There are currently 6784 online users. [Complete List]
» 2 Member(s) | 6782 Guest(s)
