Philco 611T Finish
The 611T should, I think, look like a 610T. Medium Walnut overall with a heavy coat of Perfect Brown on the bottom trim, or a light coat of Extra Dark Walnut on the bottom trim.
http://philcoradio.com/gallery/1936b.htm#i
Philco 611T Finish - by gregb - 03-11-2016, 07:40 PM
RE: Philco 611T Finish - by OldRestorer - 03-11-2016, 09:43 PM
RE: Philco 611T Finish - by Ron Ramirez - 03-11-2016, 11:00 PM
RE: Philco 611T Finish - by gregb - 03-11-2016, 11:24 PM
There are currently 9387 online users. [Complete List]
» 1 Member(s) | 9386 Guest(s)
