Thinking about buying model 630 Console?
Yes, its just a hobby.
If I buy it I hope the shadow meter works:  I don't have any Philcos with a shadow meter.  And I know this one is only a 6 tuber so it is nothing special as far as performance goes.  Just something for me to keep occupied and reapair.
G.
RE: Thinking about buying model 630 Console? - by philconerd - 03-12-2016, 02:27 PM
I bought the model 630 Console. - by philconerd - 03-23-2016, 11:22 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6851 online users. [Complete List]
» 1 Member(s) | 6850 Guest(s)
