  • 1 Vote(s) - 5 Average
Another Cantankerous 89-123
Hi Hugh and welcome to the Phorum,
> Anyone have some good advice on how to clean tube sockets?
Deoxit works well for me, just  make sure that it is dry out before powering the set up.
>Tomorrow I'll get out the scope and see if I can figure out if the oscillator is working properly
You can listen to it in another receiver tuned to the same frequency + the IF frequency. You can use a transistor set placed near the osc tube.
Glad to have you aboard!
Another Cantankerous 89-123 - by Hugh C - 03-12-2016, 09:58 AM
RE: Another Cantankerous 89-123 - by klondike98 - 03-12-2016, 01:16 PM
RE: Another Cantankerous 89-123 - by Radioroslyn - 03-12-2016, 09:54 PM
RE: Another Cantankerous 89-123 - by Mondial - 03-12-2016, 10:46 PM
RE: Another Cantankerous 89-123 - by Steve Davis - 03-12-2016, 10:58 PM
RE: Another Cantankerous 89-123 - by Hugh C - 03-13-2016, 04:09 PM
RE: Another Cantankerous 89-123 - by Hugh C - 03-17-2016, 12:28 PM
RE: Another Cantankerous 89-123 - by markmokris - 03-17-2016, 01:00 PM
Restoring Philco 96
There are currently 6977 online users. [Complete List]
» 5 Member(s) | 6972 Guest(s)
AvatarAvatarAvatarAvatar
