Rebuild Crystal Phono Cartridge Philco 41-605
As I mentioned earlier West-Tech is the only place I know about.  However, Kirk (OldRestorer) has recently announced he has successfully rebuilt a cartridge or two and is even growing his own crystals.  Maybe give him a shout and see if he's ready to take on a trial customer.
http://www.philcoradio.com/phorum/showth...?tid=14111
RE: Rebuild Crystal Phono Cartridge Philco 41-605 - by Eliot Ness - 03-13-2016, 10:39 AM
