Grill fabric
Pattern #1 is supposed to be Philco 70:
http://grillecloth.com/pages/gallery.php
Carl
Northern Panhandle, WV
Grill fabric - by Music in a bottle - 05-16-2009, 11:23 PM
Re: Grill fabric - by Carl Travis - 05-16-2009, 11:37 PM
Re: Grill fabric - by Pol-Cat - 05-26-2009, 08:26 PM
There are currently 8639 online users. [Complete List]
» 1 Member(s) | 8638 Guest(s)
