Plate Voltage on a Philco 37-650-6J5 tube
Hello
Thanks for the reply,I did sand the pins and used a very small round file
on the tube base holes and used a tooth pick with some dioxit contact cleaner
on it,but will try again thanks so much Rick
RE: Plate Voltage on a Philco 37-650-6J5 tube - by onlyrick - 03-15-2016, 09:09 PM
Restoring Philco 96
There are currently 7517 online users. [Complete List]
» 2 Member(s) | 7515 Guest(s)
