Voltage on the chassis Philco 38-8
Stan
Why don't you first unplug the set and measure 1) capacitance from either power plug pin to the chassis, and 2) resistance of the same.
Also, inspect the tone control switch. It seems coupled with the power switch, see if there is grime or whatever soiling there that can create leakage.
Then we can proceed.
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-17-2016, 03:53 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 10:10 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 11:09 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 09:37 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 11:45 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-19-2016, 10:00 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 10:08 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 02:00 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 09:05 PM
Restoring Philco 96
There are currently 7433 online users. [Complete List]
» 3 Member(s) | 7430 Guest(s)
