RCA 28x5 help
Looks more like mine, I had to refresh my memory. I shot some photos today. It looks good however never found a decal set for it so I work from memory.
https://www.flickr.com/photos/92577012@N...5911715392
I had to lose the photo finish on the two columns that adorn the front.
RCA 28x5 help - by SteveG - 03-17-2016, 08:46 PM
RE: RCA 28x5 help - by Paul Philco322 - 03-17-2016, 09:19 PM
RE: RCA 28x5 help - by SteveG - 03-17-2016, 10:14 PM
RE: RCA 28x5 help - by Paul Philco322 - 03-18-2016, 04:32 PM
RE: RCA 28x5 help - by Joe Rossi - 03-19-2016, 09:03 AM
RE: RCA 28x5 help - by SteveG - 03-18-2016, 04:59 PM
RE: RCA 28x5 help - by SteveG - 03-19-2016, 06:57 PM
RE: RCA 28x5 help - by SteveG - 03-26-2016, 06:29 PM
RE: RCA 28x5 help - by Arran - 03-27-2016, 04:24 AM
RE: RCA 28x5 help - by KCMike - 03-26-2016, 10:27 PM
RE: RCA 28x5 help - by SteveG - 03-27-2016, 12:32 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 2417 online users. [Complete List]
» 3 Member(s) | 2414 Guest(s)
