Voltage on the chassis Philco 38-8
Sorry, I failed to mention,.. I replaced the caps..
Stan
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-17-2016, 03:53 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 10:10 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 11:09 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 09:37 PM
RE: Voltage on the chassis Philco 38-8 - by Stan the Man - 03-18-2016, 11:39 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 11:45 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-19-2016, 10:00 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 10:08 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 02:00 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 09:05 PM
Restoring Philco 96
There are currently 7694 online users. [Complete List]
» 3 Member(s) | 7691 Guest(s)
