Philco 40-150 Code 121 Antenna ?
Chuck
I am very sorry. I did not mean to be crude or otherwise. I will be careful from now on and not use an A followed by two S letters. That's what I get for trying to copy Philco.
nv3g
Oscar
Philco 40-150 Code 121 Antenna ? - by NV3G - 05-19-2009, 03:39 PM
Re: Philco 40-150 Code 121 Antenna ? - by NV3G - 05-19-2009, 05:08 PM
Re: Philco 40-150 Code 121 Antenna ? - by NV3G - 05-19-2009, 05:14 PM
Re: Philco 40-150 Code 121 Antenna ? - by NV3G - 05-19-2009, 05:31 PM
Re: Philco 40-150 Code 121 Antenna ? - by NV3G - 05-19-2009, 05:34 PM
Re: Philco 40-150 Code 121 Antenna ? - by NV3G - 05-23-2009, 08:38 AM
There are currently 9935 online users. [Complete List]
» 1 Member(s) | 9934 Guest(s)
