Voltage on the chassis Philco 38-8
OK, I took the caps out of the circuit and this is what I found..
Hot on the switch, switch off, No voltage,.. with the switch on, 35volts.
Neutral on the switch, switch off, 24volts,.. with the switch on, 64volts.
Measurements were taken between the chassis and outlet ground..
Stan
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-17-2016, 03:53 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 10:10 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 11:09 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 09:37 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-18-2016, 11:45 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-19-2016, 10:00 AM
RE: Voltage on the chassis Philco 38-8 - by Stan the Man - 03-19-2016, 10:42 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 10:08 AM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 02:00 PM
RE: Voltage on the chassis Philco 38-8 - by morzh - 03-20-2016, 09:05 PM
Restoring Philco 96
There are currently 7095 online users. [Complete List]
» 4 Member(s) | 7091 Guest(s)
AvatarAvatarAvatarAvatar
